Waht would be the proper configuration to make a adapter to go from a 15K stereo output from a CD player to a summed 600 ohm balanced input to the next device in a chain?
I don't want to use a Y adapter.
Its really 600 ohm.
Didn't want to use an op amp. I was thinking a passive circuit using resistors.
Hi Joe!
I would try a pair of 1K resistors, one on each of the 'hot' outputs of the RCA, into the 600R input 'hot'. The 'cold' of the 600R input I would return to the RCA common ground through a 560R.
Depending on how close to 600R input impedance actaually is, we will have a loss on the order of about 10dB.
The 1K resistors will prevent the CD player output stage from driving too hard on signals that are not common to both channels.
A transformer could be employed if full isolation is needed (ground loop), but it will have a very low output (mic level).
http://www.edcorusa.com/products/couplers/s2m-3.html
