Howdy!
I'm replacing the output transformer on my 65 Fender Super Reverb. Ive settled on the Hammond 1650NA. Now, the curios thing is that Hammond mentions it having 40% screen-grid taps on the primary for Ultra-Linear operation. Now, I'm a beginner, but I know Fender=Awesome clean amp and Ultra-Linear=Hi-fi and Hi-fi=Super clean (duh), and I was wondering how I could incorporate this into my amp. I'm pretty handy at working on old fenders, so I can probably handle any wiring required.
I've poked around an old Mullard 5-20 schematic and I can see how these taps are incorporated, I'm really just wondering if these are feasible in a Fender.
Why don't you try?
You may love the sound. I remember long time ago one ultra-linear class A guitar amp, it's sound was awesome.
In the early 70s Fender used the ultralinear output design, not the most desirable amps in the Fender lineup, I'm being polite.
Craig
Craig
Well, I'm thoroughly afraid of blowing up a $122 xfrmr. But I guess I could try. The Mullard schem shows 1k resistors between the screens and the 40% taps. Would those be the same for a fender?
Yes, I've seen the 135 watt Ultralinear Twin... but you have to take into account that it was CBS and they could ruin even the best (the silverface era... ughhhh) of ideas. I'll go ahead and make it switchable so I can see the results.
Guitarist who claim to have heard both are almost unanimous that the UL approach is less desirable when using the amp for guitar. Is the OP tranny intended to be used on either design?
The UL used SS rectification with no choke. The “normal” ones used tube rectification and a choke.
Schematic for the UL model shows 470ohmers on the screens. Same as with the non-ULs including the original 1965 and the reissue.
Reissue:
http://www.schematicheaven.com/fenderamps/65_super_reverb.pdf
Original 1965
http://www.schematicheaven.com/fenderamps/super_reverb_ab763_schem.pdf
UL
http://www.schematicheaven.com/fenderamps/cbs_70w_mstrvol_pullsw_super-pro-bmstr_rev.pdf
Reissue:
Original 1965
UL
Honestly I doubt you would like the sound. The Fender "clean" tone is really not all that clean. It has lots of harmonics and color. Try taking an electric guitar and recording it directly into a computer and you will see the direction that ultra linear will bring your tone. A truly clean tone - an electric guitar running direct into some hifi speakers - will sound very thin and bland.
oldmanStrat said:yeah, but you guys aren't telling him how to do the UL...
Disconnect the pre-existing screen grid supply from the screen grids (pin 4 usually). (Easy enough to just remove the old 470R or 1k screen resistors that are often wired right on the socket)
Connect the transformer UL taps to the screen grids (In the same way that you would connect the anode connections to the anodes really... You sure you're pretty handy at this, you've asked a very simple question?)
I will readily admit that my modding of Fenders is based entirely off of basic stuff. I generally work with the eq and preamp stages, and I occasionally convert the power stage to use 6CA7s. I've never dealt with a true tube Hi-fi circuit, so my understanding of the ultralinear designs in them is next to nil. I was really just worried if the values of the screen grid resistors would change, or something along those lines. I'll give this a try. Who knows, I could make it a dandy new monoblock... 😀
jjman said:Guitarist who claim to have heard both are almost unanimous that the UL approach is less desirable when using the amp for guitar.
True, unless the case is of amplification for acoustic, then it seems reversed.
Cheers!
On ANY 6L6GC Output Fender you should change those 470 Ohm 2 Watt Carbon screen resistors to 1K 5W wire wound. The old 470 Ohm resistors often change their values quite considerably and after a bias failure are often open circuit. I've even seen them looking fine by a quick visual inspection but have had them fall out in 2 pieces when unsoldered to do the upgrade to 1K 5W. They can also be the source of quite a bit of "snap, crackle and pop" noise.
If using Ultralinear DO leave the screen resistors in place between the screen and the Ultralinear transformer connections.
Ian
Ian
Wavebourn said:Why don't you try?
Almost, it was late 70's, minor detail, doesn't matter. I had to replace a 50W OT placed in a wrongly repaired Bassman 135, and placed a huge UL OT, but I also placed a pair of switches to use it in tetrode mode, UL mode, and triode mode. You could try it!
I agree with Geek, it makes sense for acoustic and jazz guitars.
Too clean for a Telecaster, it sounds thin.
What would be the best way to give it a triode mode? Could I just connect the screen-grid taps to the 40% windings and disconnect the anode connections?
Well, the UL doesn't clean up the preamps, only the power amp. And at that only within the power tube stage. it won;t cure imbalance in the phase inverter or something.
The Seymour Duncan convertibles were UL, the old Sunn amps were as well. There is plenty of precedent for UL guitar amps that sounded just fine. Such a conversion won;t change your fender Twin into a hifi.
The main argument against them in guitar amps - from a manufacturer's point of view - is that the extra taps in the output transformer cost more than a couple screen resistors.
Enzo said:Well, the UL doesn't clean up the preamps, only the power amp. And at that only within the power tube stage. it won;t cure imbalance in the phase inverter or something.
hey Enzo,
Would you send an email to your Ann Arbor neighbor please?
cheers,
Douglas
Miniwatt said:Anodes disconnected?I've got a feeling that's not going to work...
Some bum I saw had a frankenchamp made so he could switch between triode and pentode mode by reconnecting the screen as the "anode". I dunno. If that isnt the way, then what would be?
It is the right way to fry screen grids of your tubes turning them into triodes permanently. However, fried wires from screen grids can short tubes inside making them absolutely dead. Dead tubes can damage your new output transformer and some other parts as well.
Anodes must stay connected always. You may use 2 pole-3 position rotary switch. In triode position connect screen grids (through 1K 5W resistors that must be soldered permanently to screen grid taps on tube sockets) to anodes (of the same tube!); in UL mode connect them to 40% taps of your transformer (of the same tube!); in pentode mode connect them to B+, where they were before modification.
- Live Sound
- Instruments and Amps
- Ultralinear fender?
