Dear All,
With this email, I would like to announce the release of Ultimate Equalizer V6. New Features Implemented in Ultimate Equalizer 6.0 – Digital.
http://www.neumann-kh-line.com/klein-hummel/globals.nsf/resources/o800aram_bda_e_517277_rev_231106.pdf/$File/o800aram_bda_e_517277_rev_231106.pdf
There is also Convention Paper 7262, Presented at the 123rd Convention 2007 October 5-8 New York, NY, USA – “Multi-Source Room Equalization: Reducing Room Resonances”, John Vanderkooy
Effectively, UE now offers two methods of room equalization, that can be used together in minimum-phase or linear-phase modes: CABS and FIR inverted filtering.
UE6 is the first fully digital DSP version, that will see the analogue waveforms only at the loudspeaker terminals. This is due to LynxAES16 digital sound card and miniDSP ICE AES/EBU digital amplifiers. It is also a step-up in performance and features, making this release the best DSP engine ever released by Bodzio Software.
For more information, please visit http://www.bodziosoftware.com.au/
Best Regards,
Bohdan
- Implemented CABShttp://vbn.aau.dk/files/62729248/LF_sound_field_control.pdf
- Long Channel Delays: 0-168ms delays. This feature allows for adding long delays to each channel for creating special “echo” effects in QUADRO (or other) configuration – just use your imagination and experiment.
- Convolution engine has increased number of partitions to 16. The original 8-partition option still available for the lowest latency.
- 7.1 HT system configuration available. Also 7.2HT (BBM) and 7.4HT (BBM+CABS) systems available.
- Up to 1.47Hz low-frequency resolution.
- Supports 16-channel LynxAES16 digital sound card and Delta1010LT analogue sound card.
- Runs on new Windows audio engine in WASAPI Exclusive Mode.
Best Regards,
Bohdan
