This simulator, I believe, may be used to simulate sound of any possible power amp.
Switch: SE/PP
Pot: drive
Switch: SE/PP
Pot: drive
That pic is very bad and huge! Could you redraw it as line art then I'll delete that one. Thanks.
I believe....
...that the both antiparalleled output diodes are worse than most cross over distorsions in normal amps.
But you could come closer if you put some variable feedback across.
Re: I believe....
It's not a line art, it is an art of simulation! 🙂
And actually, it is 640x458 only.
They are worse if gain of the limiter is low. When it is high, crossover distortions are low. Try! 🙂
Diodes are EXDPONENTIAL devices, not just on/off!
pinkmouse said:That pic is very bad and huge! Could you redraw it as line art then I'll delete that one. Thanks.
ChocoHolic said:...that the both antiparalleled output diodes are worse than most cross over distorsions in normal amps.
I tried.... about 20 years back during my first attempt to overcome feedback effects from microphones...
It sounded awfull. And did not properly overcomefeedback anyway.
But I used a low value for the resistor at the output, so there was almost no output at low input levels...
But wait.... I am starting to understand the cobination of the OP amp limiter circuit with the nonlinear R-2D-output.
...partially compensating..... OK, funny idea.
But do you really think that this is covering all sound effects of amps?
I mean... also the amp gurus usually live from the experience regarding special components, circuits and layouts... But I have never heard about any reliable model to predict the sound of a new circuit with new components... Everybody just guessing and the honest ones often find reality different than their guess...
Yes! 🙂
And the idea is not new! in late 70'th I simulated tube amp distortions in transistor amp such a way. 🙂
Just put the pot and the switch under the pedal and give it to a guitar player... It sounded like a compressor with variable distortions.
Late in 80'th I've seen a pedal from Boss that used the same idea. It had a pre-equalizer on input (boost of highs) and an eq on output. But they did not have a "SS/P-P" switch, also they did not put a drive pot under the pedal.
