Ultimate 10" HT sub?
big woofers
Blueprint makes a 10" long-excursion woofers that might be good for your uses. The 1001 woofer is in its second generation with a refined motor and extended excursion. It handles 200 watts RMS and has a 33mm p-p Xmax. The original iteration of the 1001 (which I own) performs well, even though its Xmax is only 28mm P-P. Bass is nice and tight even in a big reflex box with double-bass drums in the recorded material. There were also rumors of a 1003 (check out their 03-line of drivers to see exactly what kind of phenomenal performance we're dealing with here), but I do not remember if it ever saw large-scale production. Here's a picture:
http://www.missiondigital.net/images/dscf0101.jpg
(of the 1003)
