ULN Voltage regulators >=1.5A
Hello,
I use the well known and ultra low noise voltage regulators TPS7A4701 and TPS7A3301 from Texas Instruments: they are SMD parts and are amongst the best available.
But they are both limited to 1A. In addition, the negative TPS7A3301 is limited to -5V whereas I sometimes need -12V.
Do you know similar very low noise VR that would handle 1.5A, and could deliver up to -12V for the negative version ?
Thank you very much,
