UL to Pentode mode
Hello all. Suppose i wanted to forgo UL connection to output tubes and instead connect an independent regulated screen supply. Other than paying attention to the voltage (as directed on a data sheet) is there anything else to consider? Thanks for any helpful input.
Go ahead and try the switch from UL to pentode/beam power mode.
The damping factor, distortion, and power will be different, especially if you are not using Schade or global negative feedback.
A good listen will tell you a lot.
You may find that one or more of these parameters may need to be changed to get optimum performance in your system:
output transformer primary impedance, plate voltage, and plate current may be different in pentode/beam power than for UL operation.
Happy experimenting, Happy listening.
