For Sale UCore Electronics UCE-CT220L Fault Finder
Things you have for sale.
I have a UCE-CT2200L Fault Locator and Curve Tracer for sale. I have only used it a few times but when I needed it it came in handy.
sold
Here is a link to the manual: https://www.ucore-electronics.com/download/manuals/UCE-CT220L_EN.pdf
V-I test method is widely used in the World for PCB repairing. Fault detection can be done without
energizing PCB boards.
32 different test conditions can be created with different combinations of test voltage, source resistance
and frequency values.
The fact that the product has two channels allows simultaneous comparison of two different cards.
Specifications:
 Display: 4.3 inch 480 × 272 pixel color LCD with Touch screen
 Channels Number: 2 (A and B)
 Waveform: Sine wave
 Test Frequencies: 10Hz, 100Hz, 500Hz, 2000Hz
 Open circuit Voltage: ±5V, ±10V, ±20V
 Source Resistance: 1kΩ, 10kΩ
 Storage: internal 8MB USB disk for storing waveform image and firmware upgrade (bootload)
 Power Consumption: 5W
 Dimensions: 169 x 83 x 31 mm
 Weight: 295gr
