I got a UcD400 back from repair a few days ago, hooked it up today, and it has very low gain. I checked all of the gain setting resistors. This is using a SE input, with the - input grounded.
Everything functions perfectly, except it is quite a bit quieter than any other UcD400 I have in house right now.
Any ideas on this? I am stumped after about 2 hours of swapping cables, checking all connections etc.
Thanks,
Paul
Thanks,
Paul
Not sure what you mean by that... just input voltage to output voltage....
That I can tell with my ears, around 10dB less on this particular module.
-Paul
-Paul
10dB is a pretty significant difference!
If they have the same gain setting resistors then they should have the same voltage gain (the modules and power supply are exactly the same otherwise right?). Just use a 1V test tone and measure the output voltage. If the voltage gains are significantly different, which they should be according to what you're hearing, send your information to Hypex. Something clearly isn't right there.
Fixed it, lifted the trace on the - input underneath the opamp when I was swapping.
I am not sure why it broke....
-Paul
-Paul
