UCD as power conditioner
Ok, this is probably a dumb idea.
But given the output impedance of the UCD700 amps, could one be used as a AC 110 volt power conditioner?
I suppose there's enough of the RF carrier riding on the output to make that a really bad idea.
It's not a bad idea, class D is routinely employed for sine wave synthesys in high quality DC to AC inverters. However, note that audio class D amplifiers are optimized to achieve wide bandwidth up to 20Khz rather than low carrier components on the output, so they may benefit from some modifications. A 500Hz bandwidth would suffice for a power conditioner.
