UcD-18ohg x4, SDS-470, Audiofire12, XLS2000, Fuhrman PS-8RII
So I've finally accepted that I no longer have the time/drive for audio so I'm selling my stack. Crown XLS2000, Echo Audiofire12, Fuhrman PS-8RII power conditioner/delay powerup, 4 channel DIY Hypex UcD-180hg, and 2 channel diy Class D Audio SDS-470.
Hypex 4 channel: ucd-180hg x4 modules with gain resistor removed (great for high eff!) and Hypex SMPS. XLR in for each channel and speaker out is 2x 4pole Speakon. Powercon in/out for power and a power switch on front panel. Setup for rack mount only no feet but I think I drilled the enclosure for feet. Last used in 2018. Powers up.
Class D SDS-470: 2 channel module with Class D torroidal power supply. XLR in for each channel. Has stereo gain pot as well as separate trim pots for each channel. 2 pole Speakon speaker out. Powercon in/out with power switch on front. Also setup for rack mount only same deal with the feet. Last used in 2018. Powers up.
Audiofire12, XLS2000, and Furhman were from same system. Last used in 2018. All power up.
Will include diy TRS to XLR for all channels, diy Powercon cables, and a pile of 8 pole cable, 8/4/2 poles Speakons, and maybe more.
$600 takes the lot and I prefer pickup in Rochester, MN but may travel a short distance to meet. WILL NOT SHIP. I cleaned these up as best I could but there is some dust, scuffing, etc. Used in my home.
