Two-way Dibeisi PS1205-8 + JBL 2451h, can it be done?
Hello guys,
I have this 12 inch speaker with Dibeisi PS1205-8, see specifications in the photo.
I would like to make a two-way with combined Compression Driver, I thought of this jbl 2451h.
Everything is driven by a Synq Dlp 6 DSP.
In your opinion, is this marriage compatible?
I think I'll also add a SUB
Thanks for your advice
Knowing what horns you have also will help, as the directivity pattern of the horn gives you a clue as to where your polars will match.
Look at the attachment for better explanation.
JBL 2xxx or ? A frontside picture will make it easy to identify.
Also useful information to share is that is a JBL 2451H-1, meaning it has 2 sets of mounting holes with different BCD (Bolt Circle Diameter), so it fits horns with both 114,3 mm (2451H), and the 82,55mm BCD, that fits all they're "modern" 1,5" horns/waveguides without using adapters.
Reactions: GM
thanks.....but I haven't purchased the jbl drives yet, I found them in the used market for €200 a pair, drive+ horn....I thought that the characteristics are, I think, compatible with two-way, done with my 12 inch woofer.
But if there are other compatible drivers, I accept advice
Reactions: GM
That is good value buy regardless, it will be worth to put in some 2450sl/2452hSL diaphragms with Aquaplas coating though.
It is a 4" diaphragm 1,5" exit compression driver, with the shortcomings and pros that comes with.
There are plenty of options, but for 200/300 for a pair the value is hard to beat with factory new.
Reactions: GM
...in the car world, I found these two compression drivers...at affordable prices....what do you think? naturally change the horn
