Two Variacs for Coarse and Fine Adjustment.......
Hello All,
I would like to build a new tool for the shop in which I use the first variac for coarse line voltage adjustment from 0 to 130v and another variac for fine adjustment of the specified line voltage determined by the coarse adjustment. I would prefer the second variac to represent plus or minus 10 percent of the coarse adjustment over its full range so that the second variac acts as a sort of very fine vernier adjustment to the coarse adjustment.
Does this make any sense? Is it possible? Any suggestions?
David
Hello All,
David
Yes it is possible. You'll need a high (mains) voltage variac and a low voltage variac and you use these two in series. (Sometimes you find a small variac in series with a mains transformer in a tube tester to regulate exactly the voltage used for testing).
I found a 15V variac on the local auction website and it is earmarked for just that purpose.
AM
I have seen something like that set up. There was a high voltage variac and a low voltage one with a small transformer in between. I thought it worked the way I am thinking for my idea but i wasn't sure.
I have seen reference to limiting the range of any given variac using a supplementary transformer. This info is listed in any of the variac info sheets from GR but again, I was not sure if I would end up with the + or - 10% of line voltage using this arrangement. I would like the whole turn on the smaller variac to represent the very fine adjustment of the first. Is this what would result if I used them in series as you describe?
Cheers
If you have a centre tapped variac and a transformer with low voltage secondary you can connect the transformer primary between the variac centre tap and slider. If you then connect the secondary in series with your load then varying the variac will buck or boost the load voltage by up to the the nominal secondary votage (say +/_ 15 volts) O/P current is limited by the seconday current rating so only a small variac is needed. of the transformer.
Barry
