Two toroids - special deal
I have two toroids I'm letting go of. They are new in box complete with rubber mounting pads. They have potted centers and a steel band around the outside circumference. Pretty high quality from Amveco Magnetics.
The label reads:
Prim: 120v 60hz 288VA
Sec: 57vct or 28.5vct 4.68a (267va)
BUT
I have used them in the past and have dug pretty deep into them. If you cut the connectors off and seperate the magnet wire of the secondaries you actually have four independent ~15vac secondaries. (if you look at the pic the two yellow and gray sheaths each have two leads joined at the connector)
I have used them for small amps, preamps,+-15v opamp stuff etc.
Here's the deal:
Donate $35 via paypal to DIYaudio and I'll send them to you. That's $35USD for 2 X 267va toroids shipped.
Here's where I get flamed :hot: US only cause I'll send them usps flat rate and I'm eating the shipping:hot:
How do I know you donated? Forward me the paypal 'receipt email'🙂
Post here, the first post after my post gets it. If he/she doesn't follow through I'll post again that its up for grabs.
FOR CLARITY: You don't have to unwind the toroid or untape the toroid to access the four undependent 15v secondaries. Just play with the leads. PIC....
Hi Eddy,
I'm not affiliated with diy so I wouldn't know if they got it🙂
Better ask someone else😀
I'm making a list. the interest is huge in these buggers....I can probably get more. Post here if interested. I'll get as many as I can and do what I can....
wow..I got censored on the word b u g g e r s. I meant the bug, not the other thing:xeye:
Yes, still interested
If you can get more I will be happy to cough up some bucks either for the DIY donations or directly to offset shipping or the total costs.
Got numbers?
(I will be useing these to power a couple of mono-block amps from aussieamplifiers.com ... the 150 's ... :smash: )
