Can anyone provide insight into what the tradeoffs would be if I were to design a subwoofer with a pair of passive radiators that are tuned to somewhat different frequencies?
Imagine I have a given design with a single driver, amp, and two passive radiators in a specific box, and the output rolls off just a bit too soon for my tastes. Would there be any sense in adding a bit more mass to one PR in the hopes of getting a little more low frequency extension? My gut tells me it could work, but because there's no free lunch, it would also shift the rolloff frequency upwards. Qualitatively, it could come across as having a slightly less steep rolloff. Is this a common approach or is it a dead end?
Is there any way to model this? I use WinISD, but I also recently purchased BassBox 6 Pro.
Don't know how to model different passive radiators that are tuned to somewhat different frequencies, but what Brian Steele wrote in replies #12 & 14 makes sense.
Using two PRs in same system, tuned to different frequencies?
On 10/15/18, in post #15, Silent Screamer wrote:
"Let you know when I build my new sub. I can easily adjust both PR individually to find out."
Don't recall him posting any results after that.
2 resonators in a system will still have a combined tuning or Fb of one frequency.
WaVeInFoRm is correct.
Later,
Wolf
Later,
Wolf
Thanks. Any recommendations on the best tool to model things like this?
I used WinISD to generate SPL of two differently-tuned PR each in their own box, and then manually added the levels logarithmically, and the results sure didn't seem very interesting. Still, it would be nice to get those results automatically.
The question is not what will it do, the question is do you know how to write the appropriate script.
Indeed! FWIW, I summed the different specs of two very diverse drivers to make a composite to sim and it worked out pretty well, so doing it with PR specs should work OK in theory.
GM
Would it be so different from having 2 sets of speakers using the same drivers but one sealed and the other ported?
As GM said in a post many years ago they load the room in different ways why would having dual but different passive radiators be different?
Yes, because the PRs are in the same cab, so will sum to a single tuning; now if it was two differently tuned vented/PR cab alignments it would be a similar situation and using different tunings in a stereo/HT app to best overall blend with each speaker's local room acoustics is something me and a very few others have recommended when appropriate.
GM
Got it.
Makes sense in the acoustic and it did work in our old room
Would it have any influence on the amplifiers performance?
- Subwoofers
- Two passive radiators with different tuning frequencies
