Denon 755 has 2 oscillators: one at cdx2500bq reciever-decoder-whatever and the other at sm5845af filter. Both are 16,9344 Hz and are physically about 12cm from each other.
Will it be wise to use one Kwak-Clock near dsc-s (1702) and feed all that stuff from that? The reason for questioning is the physical distance between those things.
Ola said:Denon 755 has 2 oscillators: one at cdx2500bq reciever-decoder-whatever and the other at sm5845af filter. Both are 16,9344 Hz and are physically about 12cm from each other.
Hi Ola,
If the frequncy is the same I would try one oscillator. Placed in between I don't see the 6cm distance as a problem.
