Hi Gang,
I took the plunge and bought 4 of the PCB for the Amp Camp project. I'd like to set them up as monoblocks. What do I need to do? Does the IN and OUT just run in parallel?
How would monoblock ACA compare with something like the Aleph J mini?
Thank you! I was missing these details.
Be careful about the directions, looks kinda confusing.
Remember the switch can melt from excess heat. Tin the wire first, and be fast.
"The only difference between v1.6 and v1.8 is the back panel, how the connections
on the panel are wired, and the switch itself."
"If you have any questions please post them in the ACA Kit 1.6/1.8 Discussion Thread
where you will get swift and comprehensive answers."
Good luck.
Good luck.
Hi Rayma - My schematic says 19vDC input but the project website says 24vDC upgraded, is there any changes needed to use 24vDC? Can I use 48vDC? as I already have a 48vDC dc supply on hand to test with.
I haven't built these amps, so post on the ACA Kit 1.6/1.8 Discussion Thread
and all questions will be answered.
But 48VDC is unlikely to be ok.
