tweeter domes for vintage chario monitor
hello everybody
just got super cheap a pair of vintage italian chario monitor (2013 serie , it's the name not the year ) speakers (they look like three way with a woofer and 2 tweeters )
the domes of the tweeters in the middle are damaged : one bumped and the other pierced , they were made with a proprietary treatment of silk material , where can i find a repalce thet' s close to the original domes ?
I have not much experience of speakers repairs , Ichanged some rings on woofers but never domes
many thanks
peace
thanks peace
hello
thanks , but it's not that the speakers are very similar to the hyper 2 that you can see here
Chario Hiper MK2 series
chario answered me that the most similar tweeter in production now is the one in the hyper 3 , but it's way toot expensive , I would like to replace e
the silk dome and keep the original coil etc , so I'm looking for domes only not the complete tweeter
thanks peace
how to fox broken silk tweeter domes
yes they are those
I managed to fix the dome , today , luckily the dome is fastened with 4 screws , so after removing the complete tweeter I removed the 4 screws and the dome disonnected from the magnet , so I looked for a suitable piece of black cloth the best was a piece of old black silk umbrella (almost perfect thickness and almost airproff as it's waterproof ) I used uhu brand yellow glue which ramains flexible and a plastic ball as mold to maintian the shape so I could also press well the glued part with the finger , the glue is supposed to be laced on both parts , to be glued , wait 15 minutes 'till it dries and then press together , but I didn't do that , I put some glue on the black cloth patch , and put it wet under the hole , then put the plastic ball inside the dome under the patch and put everything in position from the outside using the fingers (for a few minutes as the glue is wet in positionable ) pressing without problems
I think it's a very good solution to fix domes , it's almost invisible , mass gain in minimum and flexibility and material (silk and glue ) are almost the same as original ( on the brochire of the speakers says silk with special treatment , that looks like some waterproofing elastic glue )
Many thanks to everybody for the help
Hopefully this solution can help someone else
Peace
