TV + Subwoofer + Speakers - Can we make it work??
Hello everyone,
sorry if I ask silly questions. I'm new to this stuff and English is not my native language what makes it a bit more complicated.
The bottom line is can I make it work? I want to connect Speakers and subwoofer to Samsung Smart TV.
1) I got those speakers without middle part. Originally they were for karaoke system with two mics. That's why each speaker has mono 1/8 (3.5mm) jack (see on pic).
2) I got subwoofer. Check details on the picture.
3) I got adapter to have connection from TV to speakers through optical output (see on pic).
The problems are:
1) Speakers have 3.5 jacks but subwoofer doesn't.
2) Speakers have 3 ohm.
3) Maybe more problems, let me know))
Can any of you see how it might work? Should I buy something in between? Cut jacks and insert to subwoofer (high level output)?
Or those won't work together and I should quit?
I will be thankful for any ideas!!!
Thank you!!!
At first glance it seems that you mainly need some adapter cables.
Look at Monoprice.
the optical L+R out rca to the woofer low level in L+R rca
Use a regular stereo rca to rca audio cable
Woofer L+R speaker high level out to speaker mono mini plug socket.
This is non standard but you can make up something.
For example buy two cables that each have a mono mini plug at one end, and cut off the other end.
Strip the cut ends to fit the high level woofer output terminals, red is center conductor, black is shield.
