TV sound D to A
This might be better value than the little black box DACs...
Any of the low cost converters only ever output 48kHz stereo. Whatever the audio format started out as, it will be resampled in the source device to 48kHz, 2-channel. The only way around that is to buy an expensive AVR unit. The problem has to do with encryption, DRM, and decoder licensing (which is only offered to big companies).
Beyond that issue, the dacs in those cheap converters are the cheapest, and most cheaply implemented, possible. For better audio fidelity, a converter with a 48kHz SPDIF or TOSLINK output can be connected to a higher quality dac with SPDIF/TOSLINK inputs for conversion to analog. Such dacs can be had for a few hundred dollars up to several thousand dollars. The best sounding ones tend to be expensive although high price is no guarantee of quality.
My thread with AD1862 DAC contains Optical to I2S board based on WM8804 chip (it is tested and works). Next you can build my audiophile AD1862 DAC, even with power supplies. All you need is basic soldering skills and a little determination. You can then compare the sound of this DAC with $$$$ devices. The most beautiful thing about it is, that you put it together yourself :wiz:
