Hi...I picked up a Lab-420 TT at a local thrift stor for $5.00, and it functions well but has audible rumble. I have it isolated from the rest of my audio system...could I put it on a rubber pad...would that help? Is it possible for a cartridge to go microphonic and pick up rumble? It is direct drive...could there be a problem within the drive train?😕
Feedback has always been a problem
Why the soft suspention was "invented"
A heavy block/shelf helps too
But rumble is a different matter
Anyway, you need a highpass subfilter 😉
If possible try to lubricate the bearing with fine oil, used fore sewing mashines
Or maybe fine teflon oil
Where would I find a high pass sub filter? Light machine oil I have..always go with the least complicated (and least costly) solution first.😀
"You can't make chicken salad from chicken crap ! " My Grandpa
There is a manual for the Realistic LAB-400 in the: http://www.vinylengine.com/library/realistic.shtml
If you register, you can download the service manual.
Jeff
Jeff
bereanbill said:Where would I find a high pass sub filter? Light machine oil I have..always go with the least complicated (and least costly) solution first.😀
This would be one option
http://sound.westhost.com/project99.htm
