Hello,
I am a tinkerer of sorts and have found my way into an audio project. I’m a little unsure of how speakers are sized and how to choose proper crossovers and weather or not I’ll get a “good” sound from my planned build.
I have a roughly 1970’s turntable/radio receiver/8- track player that I am going to try and add a Bluetooth receiver, onboard speakers, and then repaint and re-letter the whole thing. The 8-track has sadly gone kaput, so I have removed it to make room for housing speakers. I understand onboard speakers can interfere with the tt sound, but the tt is fairly low quality anyways.. I ha e a 5.25 Logitech woofer from the x-230 2.1 system ( I think) and a pair of small FineMost 2” speakers. I need a good crossover/filter setup to keep the woofer from overpowering the little speakers. The onboard amp is a life center unit for what I am trying to achieve, but it’s built into the main circuit board so I don’t k ow it’s specs at all.
I’m sure there will be a lot more info needed for this, but this is a start.
Speaker specs (as far as I know)
2” Finemost: 5w-6ohm (part no 29D)
Logitech: 20w-8ohm 40hz low (not sure of high)
I’ll add some pics once I get my computer up and running again.
Thanks for any help at all!
-A
-A
