SE Amplifier 6C41C 8 W
Look this amp.
DATA is
6C41C military tested matched tubes.
This tubes Rassian is a famous like 6C3C .Exelent sound.
It's Ability to here loiudspeakers woth 90-92 db.
Wide range.
Quelity transformers.
Paper/Oil military capacitors.
Input selector.
Driver is a famous 6E5P.High curent tube.
The weight up- to 14 kg.
The price is 600 USD
Look this amp.
DATA is
Wide range.
Input selector.
Tube for sale
I have the tubes for sale.
It's
GM70, 807, 6P3S (nearest analog of EL84 or 6L6) and 6P3S-E,
6C33C,6C41C, 6P45S, 6P15P, 6P14P (EL84), 6P9,6J4...6N2P,6N1P, 6N8S (analoge of 6SN7),6N9S...
It's
Re: Bass Speaker
That's a really low SPL for such a high Fs on an 18" driver. Is there a typo?
Cheers!
nafanja said:
18" BASS Speaker
Frequency 50-4000
Preasure 99 db
Cheers!
Fs 27 Hz
Re 4.2 Îhì
Qts 0.26
Qes 0.27
Qms 6.6
Vas 566 l
Dia 390 ìì
BL 18.1 TL*ì
Mms 124 gramm
Cms 0.28 ìì/Í
Le(1êHz) 0.8 ìHn
Õmàõ7 ± 3 ìì
Xmeh8 ± 10 ìì
Re 4.2 Îhì
Qts 0.26
Qes 0.27
Qms 6.6
Vas 566 l
Dia 390 ìì
BL 18.1 TL*ì
Mms 124 gramm
Cms 0.28 ìì/Í
Le(1êHz) 0.8 ìHn
Õmàõ7 ± 3 ìì
Xmeh8 ± 10 ìì
For Geek
To make 27 Hz and more than 99 real db -is a hard work.
With a price for 200 USD.
Many German and Europe spweakers have print 96-97 db, but it's no truth.Real 90-89 db.
This problem was be where i was try to buy the speaker for forstex 96 db.
This speker made not for concert work, the silk-paper cone is give soft mechanic sistem and well for tube eqipment.
But if you need to make more - you may use horn sistem or double speakers ?where speaker after speaker.
99+3 db = 102 db. Or open dufle or in closed box.
Closed box is may be near inside 90-120 L.
Re: For Geek
Sorry, you miss my meaning.... 45-50Hz OK and 110 dB. Eminence does this quite nicely.
Not for home stereo, but bass guitar.
Cheers!
nafanja said:To make 27 Hz and more than 99 real db -is a hard work.
Cheers!
For Geek...
Tell me please. where I can find 110 db bass speaker with this true spec?
/Sorry, you miss my meaning.... 45-50Hz OK and 110 dB. Eminence does this quite nicely.
Not for home stereo, but bass guitar./
If you about that thios a little loud - no. I think for 1 W tube gaear is OK...
I am a tube lower... And this kind 96 db - is enough for me...
But interesting ook where Fr and 50 Hz I may find for 200 USd?
Caps and diodes
Caos
paper oil caps for sale...
Alununium .
100mf -1000V
200mf - 1000V
Very good for for tube amp gear.High end amps...
Exelent sound in a powr block.
make emoution quick soumd. High puls rating.
For taste 100 mf for 80 USD
200 mf for 150 USD
At the picture tue 25 A (amper) /1000V fith radiator.
The price for one withot radiator 10 USD.
With radiator 20 USD.
Very good for power blocks and regenerators for your high end gear...
Caos
Alununium .
100mf -1000V
200mf - 1000V
200 mf for 150 USD
The diodes for sale!!!
The diodes too... at the picture...
I am use this ind at regenerator with regulated frequency of out 50-100 Herz.
My Cabasse , super CD Philips d Pro2 and AD1862, tube amp baby is very sencictive for good power requency and out of noise and other...
The sound with this kind diodes make the sound more quickly and the mid is stay fidly...)))🙂
You need just tast this at your audio sistem...
Your dream- ware resistors for sale!!!
The ware military factory vantage USSR (Russia) ware resistors...
10-25-50-100 VA
Choose parameters for yourself.
This kind of resistors I am use at my amps...
Exelent variant for high-end and hard eqipment...
Price is 1 resistor 10 USD
Price for 10 - 8 USD
10-25-50-100 VA
carbon non-induction resistor
This carbon resistors exelent for audio eqipment...
It's need some time for plaing in sistemf or criastalisation - and soumd will be the same like the Ricken Ohm and other famous resistors...
It's 0.5 , 1 VA, 2 Va and more...
The spec you will see at the picture
the price is 2 USD for each...
- Vendor's Bazaar
- Tubes,Tube amps, Loudspeakers...You DREAM Here!!!From...
