hey
i got 2 OPT for free some time ago with these specs:
pri 1.75Kohm,
sec 2.5, 4, 8ohm,
taps 20%,
weight 4Kg
no ideer about wattage.
and i have no ideer what to use them for... guessing it would have to be some parallel push pull? but i could really use some ideers, as to what tubes would make sence with these OPT.
I am open to any ideers, dont have to be the usual tubes.
-heinrichs
pri 1.75Kohm,
sec 2.5, 4, 8ohm,
taps 20%,
weight 4Kg
-heinrichs
They should be large enough for PPP EL34 (4 of them). I do not know the quality of the transformers, but they would do well for guitar amp service. Do you play guitar?
1.75K Ohm is pretty low for a single pair of tubes.
Daniel
Daniel
8.8 Lbs, sounds like maybe a 70 to 100 Watt OT (for 20 Hz low end, would be more, maybe 120 Watts for 30 Hz low end). The low primary Z sounds like for parallel tubes. On the 20% taps, is this 20% of turns or 20% of impedance (.45 turns)? If 20% of turns, I think maybe EL84 has this 20% spec for UL mode. Could be made to work for a UL sweep tube too if the DC level could be dropped as well.
