This is for my first tube project. I've researched kits, and considered doing my own design, but the TL SSE and SE sound like a great way to get started.
I am looking for > 3w/ch to drive my bedroom speakers.
I'm trying to get my head around the advantages /differences of the TSE vs. the SSE.
BTW, what is a DHT amp?
Thx,
Rob
Thx,
Rob
DHT: directly heated Triode (like 2A3). The Simple SE should be easier to build, probably will cost less overall, and potentially can give a few more watts as well. Russian and Chinese 6L6s are quite inexpensive.
Simpler to build, maybe. Both are on PC boards, so not a big deal. I know the SE involves messing with some heat sinks that require some mechanical fiddling, but not a big problem. As for watts, it's hard to say. The SE uses a thing called "power drive" that can really make the most of low powered DHT's. Plus you get the sonic advantage of the DHT, but the downside of the MOSFET in the way. I have built the SE and enjoyed it with 300Bs. As with many (all?) SE designes, the output transformers make a lot of difference!
In summary:
TubeLab Simple SE is a more cost effective design using readily available tubes, lots of tube choices, requires no adjustments once built and can easily deliver 5-8W or so depending on tube type, cathode R value and B+ voltage. It uses common output tubes such as such as EL34, KT88, 6L6GC, 6V6. It can also be configured to operate either in triode or ultralinear (UL) mode.
The TubeLab SE is a bit more advanced (and expensive to build), using directly heated triodes, fixed bias, regulated voltages, MOSFET coupling, etc. It can produce around 2W using the 45 tube, and maxes out around 8W using the 300B tube ($$$).
There is loads of info here: Tubelab Home
and here: Tubelab - diyAudio
I couldn't decide either and bought both boards........which are both about 80% complete.....so many amp, so little time.
Thanks guys.
I'm thinking now the Simple SE would be better for a 1st project.
I am willing to invest in the OPTs. Any recommendations on OPTs for best sound quality?
Driving 8ohm speakers, 3-5w/ch. I may try the KT88s.
Thx,
Rob
Thx,
Rob
For a bedroom amp the Simple SE is the most build and forget. You don't have to check bias or set it.
As far as OPT's you need not spend alot to get a great sounding amp.
For the KT88 option I used the edocr 15W 5k8 I think it is their GX series. If I would do over, I would probably go with the 25W CX series from EDCOR.
If you have really "Prime" bedroom speakers and a great set-up then spending more on a set of Electraprint, Onetics, or others could be considered. Then there are the boutique OPTs but $$$WOW$$$. The term "better" almost doesn't apply at that level.
I have both the Simple SE kt88 and the Tubelab SE 300b the later uses the 25W CXSE Edcors. I couldn't decide either.
My Simple SE is in my bedroom because of simplicity.
I also have both. For a bedroom amp, I would agree that the SSE is the way to go. To my ears, the differences between the two amps are the most apparent during dedicated listening sessions (sitting alone with the music in "the spot"). The SSE just works and you don't have to hunt on eBay for tubes.
I have the big Edcor CXSE as well for the SSE and One Electron UBT2 for the TSE. The UBTs do not have an UL tap anyway and the huge CXSEs are great match when using big tubes in the SSE, like KT88s...awesome bass.
Thanks guys.
Thx,
Rob
If you are patient, you can pick up a pair of Transcendars on Ebay. Gery from Transcendar does not always have them listed, but they are listed quite regularly.
They are 10W, and are available in 3.5K and 5K primaries with 8 ohm secondaries. They are also available with and without UL taps. I would get the UL taps since you would then have the choice between UL and triode modes.
Here is a completed auction for reference:
Pair 5k UL Audio Output Transformers for SE amp, 8 ohm - eBay (item 280457884232 end time Feb-07-10 10:40:33 PST)
Looks like the prices on these are creeping (jumping!!😱) up. They used to be "buy-it-now" for $120+$15 shipping.
The trick to finding these is to search for Gery's user name, which looks like he just changed to Transcendar, since he does not put "Transcendar" in the auction title. You can also get these directly from Transcendar.
For a little more cash, look at the Electra-Prints (around $200-$220). They are also sometimes listed on Ebay (search for user name "electraprint"), or you can order Directly from Jack.
If your wallet is a little fatter than above, check out the James 6123HS. These are around $259 a pr new from TCtubes.com stateside, and are also regularly listed on Ebay. One nice thing about these (besides looks and quality, etc) is that they have both multiple primary impedances (2.5K, 3.5K, & 5K) and 4-8-16R secondary impedances.
If all of these are above your budget, as already mentioned Edcor has several choices at different price points and are a great value.
Don't forget the Magnequest Robin Hood series. $99 each last I looked. I have a pair of the Parafeed units with nickel pin stripes. On my TubeLab SE amp, sound great. For a lot more $ you can get units like the FS030, I just took delivery on a pair of these. Kind of surprised they didn't come in crushed velvet pouches, but I think it would be really hard to beat them. Yes, expensive, but it is a long-term investment. Not to mention, it takes a long time to get them. Oh, and One Electron which you can get through Antique Electronic Supply are inexpensive and from people I've talked to, very nice indeed. I have not personally heard them, but they seem to stand the test of time.
Definitely. The Simple SE is pretty much build it right and it will play. The Tubelab SE does take some adjustments to make it work, and the component density on the PC board is about double. The Tubelab SE can be a more revealing better sounding amplifier IF you spend the money for good components, tubes and transformers. If you are on a budget you can get quite a bit more sound for your dollar with the Simple SE.
The KT88 can make 12 to 14 watts per channel in ultralinear mode. If this interests you make sure that you get output transformers with the UL tap on them. If you have big speakers and want room shaking bass the big Edcoe CXSE 25-8-5K's are the ticket. They sound good overall too. The Transcendars are also good. I have a pair of his older transformers in one of my Simple SE amps.
Looks like the prices on these are creeping (jumping!!) up. They used to be "buy-it-now" for $120+$15 shipping.
I liked the older ones so much that I bought 10 pairs. I paid a lot less. It was a few years ago.
George: This level of power doesn't appear to be shown on your Simple SE sims page. What B+, current, load, etc is needed to achieve this? Does this result in a tube life of 20 minutes or less? Just curious.
Albireo13,
For a bedroom setup, in my opinion the Tubelab Simple SE will be more practical. It is actually a plug in and forget amp. No bias to set and no maintenance required. The sound is grteat, by the way, whether using EL-34s, KT88s, 6L6, KT60s, 5881s etc.
I built 3 Tubelab amps because in the beginning because I too cannot decide for myself. I used One Electrons and Transcendars on my Tubelab SSE and Electraprint OPTs on my Tubelab SE. I 'm enjoying all of them what ever I choose to be the "amp for the day". Great little amps. Hum free, big soundstages, palpable bass, crystal clear highs and involving midranges (in "audiophile talk"). What is there not to like. Godspeed.
John Revilla
John Revilla
I don't think there are any UL examples on the "Tubes & Transformers" page. I'd look at the line where he indicates the KT88 is capable of just over 9 watts with 500 volts B+ and a 3K load. Idle current is 71 mA achieved via Rk=680 ohms. I'd guess in UL mode you'll get 50% more power, so that puts it in the territory that George mentioned above.
Yes, all those simulations are done in triode. UL is a little more complex due to the screen currents.
Cool...I didn't realize that....
I've designed and built an amp similar to the Tubelab SE. In fact, I was heavily inspired by the Tubelab SE during the design process. I just wanted to try this tube thing and have now caught the bug completely. My little amp delivers about 5 W on a good day in UL mode. I'm using the small Edcor CSE15-8-5K ($20/each). I have also tried with the bigger CXSE25-8-5K ($75/each). The amp does sound better with the bigger transformers, but it really does sound very good with the small ones too.
Study the Tubes & Transformers page on Tubelab.com in detail. The page might be blank at the top (at least that's the case in FireFox) - don't be discouraged just scroll down...
If you're just looking to get your feet wet, just get the small Edcors. You won't find better transformers at this price point.
~Tom
~Tom
No glowing tubes, just as noted by others, UL mode. I was running the big Edcor CXSE25-8-5K OPTs and EH KT88's at a fairly high (but not ridiculous) current in a Simple SE using an Allied 6K7VG power transformer. B+ was about 440 volts and the current was around 75mA if I remember correctly. It ran for a long time (months) before I stole the OPT's for a Tubelab SE. Those same tubes are still running (2+ years) in a different Simple SE which uses a Transcendar OPT without UL taps.
The simulations come from Tubecads SE amp cad which only does triode mode. Bhe bias currents and dissipations are valid for any case where the plate and screen grid operate at the same DC voltage. The power output and distortion numbers are only valid in triode mode. These simulations have proven to be fairly accurate.
- More Vendors...
- Tubelab
- Tubelabs SE vs. Simple SE ??
