Various Tubelab populated PCB Board for sale.
I populated them with quality parts, then never completed the builds.
They should all be working, but you may want to double check them in case I made any mistake on them.
Need to add shipping from Brooklyn 11211.
Accepted payments:
- 1x Tubelab Simple SE (dated 2006, no cathode resistor installed), $100
SOLD: 1x Tubelab SSE (dated 2012, 680r cathode resistor installed), $100- 1x Tubelab Simple SE (setup for KT88), $100
SOLD: 1x Tubelab TSE-II (set up for 300b)SOLD: 1x Tubelab TSE-II (set up for 45, photo attached), $100SOLD: 1x Tubelab SSE (dated 2012)SOLD: 1x Tubelab TSE-II (dated 2020)- 2x Tubelab Universal Driver Board PCB 2015, new unused $30 each
Accepted payments:
- Zelle
- Paypal (add 3% fees if "as purchase")
- Venmo (add 3% fees if "as purchase")
- Revolut
- Wise
I do have other two for 300b / 2a3 / 45, installed in two amps I have. I have not listed them yet. I'm out traveling at the moment and will be back home after Oct 16. I'll set a reminder to list them after then.
to be honest I don't remember what resistor I have soldered on it. I suppose something for an EL34. I will check once I get back home in 2 weekscurrently configured to use ?
You'll need a different power transformer than usually specified, something yielding around 300v (instead of 400+) B+. But aside from that, component value changes should be few, and there are surely others on this forum who have done just this.
Also, even if you do use 6l6 family tubes, you still have the choice to go UL or triode mode. But in any case it is a good design, the pcb layout leaves you some room to work, and there are plenty here happy to help.
-Loren
-Loren
If you have another one set up for 300b, I'd be interested as well - possibly the tubes as well if you are also selling them?
@ceylon.mooney Sorry for the delay replying. I am still out of the country traveling. Will be back home on Wed Oct 23 and I'll check the board then. I have soldered them a couple of years ago so I can't remember much about it anymore. I would imagine swapping from EL34 to SE 6L6G may require desoldering the cathode resistor and soldering one with a different value. Should be fairly easy.
@ceylon.mooney I just checked and found as follow:
- 1x Tubelab Simple SE (dated 2006, has no cathode resistor installed)
- 1x Tubelab SSE (dated 2012, has 680r cathode resistor installed)
- 1x Tubelab Simple SE (setup for KT88, not sure of cathode resistor value)
Also added for sale other two TSE boards. I have one of them installed in an amp with 300b, another one installed in an amp with 45.
In case of sale I will be removing them from the amp.
Hey woodturner-fran. No prob. Happy for you to take it. Sorry, wasn't trying to jump the queue.Yes - and you'll see from my post no. 10 above I am interested in a 300b set if you have it.
Tubularfluxus, if the sale to woodturner-fran doesn't work out, send me another dm.
No hassle at all @astrojet!Hey woodturner-fran. No prob. Happy for you to take it. Sorry, wasn't trying to jump the queue.
