I've got a tube/transistor tester of some kind of Italian brand. The problem is that I don't have the service manual and without it is impossible to operate it.
Does anyone know this one, or better, has anyone a operation manual for this tube tester.
The text on the tester says that it's a
Provavalvole / Provatransistori model 891 and it comes from Chinaglia Belluno Italy.
CHINAGLIA
You could try this guy for help:
http://www.geocities.com/CapeCanaveral/8443/contatta.html
Cheers,😉
Cheers,😉
Chinaglia Tubetester Mod. 891
Hello Sjef,
I see your question about Chinaglia Belluno Mod. 891 Tubetester.
Did you find the corresponding User Manual for this tester?
If yes, could you please send me a copy of the document or indicate where I can be provided for such documentation.
Indicate the cost condition for a postal expedition if an Internet tranfert is not possible.
Best wishes for new year and success in old radio restoring activities
Best regards
Dan HUMBLOT
8 Rue FOURY
92310 Sèvres
France
Hello Sjef,
Best regards
Dan HUMBLOT
8 Rue FOURY
92310 Sèvres
France
Hi Dan,
No unfortunatly I have never found any manual for the tube tester. I have stopped searching for it after a while and it now resides in my closet for the last two years, maybe someday ??????
The manual for this tester is available by mail for 11 Euro here:
http://www.geocities.com/CapeCanaveral/8443/tmprovav.html
The site is in Italian, but I believe he speaks English as well.
Contact information here:http://www.geocities.com/CapeCanaveral/8443/contatta.html
Note I expect if you could not read Italian well enough to understand the information he provided on his site, that the manual itself might be a bit hard to understand.
Incidentally this model is an emission based tester, imo not that useful.
I'd look for something that tests for transconductance. (Regardless of what he says to the contrary, although his point about tester to tester variations even with transconductance testers is well taken.) Testing the limits of my not so good Italian reading this site..
If anyone is still looking for this, I "scanned" (took pictures actually, so it is bit skewed) of mine manual. I processed PDF with an OCR tool, so that some text parts can be selected (if you need it for translation):
https://grunfy.com/img/provavalvole_891_manual.pdf (my manual, with some extra tube data)
https://grunfy.com/img/provavalvole_891_manual_original.pdf (original)
There is also short one german manual which can be found here,together with pictures of original manual, which I converted to PDF (I run OCR tool on that one too, so, some text parts can be selected):
Italienisches Röhrenprüfgerät Provavalvole Mod. 891 von Chinaglia
It is an emission based tester, but very easy to use. I use it for quick testing (it also detects shorts) before firing up Hickok...it is also much smaller and not so heavy so lot easier to move around if needed.
- Design & Build
- Equipment & Tools
- Tube tester
