Tube Dampers
Hello All
I came across this while searching for possible improvements in tube.
Tube Damper Comparisons
How exactly do these things work, and why are they then not made by people who make tubes?
Are the electrons shaking the tube so to speak?.
that much?? cant imagine that.
What is it really damping /cushioning??.I can understand only shielding aspect of some of these.
BR
Amit
DIY yourself and try it, first.
You need 1mm steel wire and 3 teflon pieces (from teflon coax).
Something like this.
(IMO, teflon socket is much beter idea than tube damper).
Sometimes, simple elastomer "O" rings positioned over the micas can help a marginal tube. Both neoprene and silicone rubbers work, with the silicone being a bit more heat resistant.
As for sockets, mica loaded phenolic has vibration damping properties. That's something the folks who make pricey, "audiophile", stuff would prefer you didn't learn about.
Hi. thanks for the input! and thank you all too !
How likely am I to Hear the difference if im using ecc83/81/82 as pre amp in a single ended amp. Is it also possible to hear the difference easily if was to put this ring or similar stuff on an ECL86?
By Marginal or not good tube you mean one which has an internal assembly loose part. If we are damping virbations which i understand is being attempted. ..is the mains tranny on the chassis rocking the floor and everything fixed to it?h
Just asking. .. thanks
BR
amit
all amplifier tubes are microphonic - more or less;
e.g. the control grid is a bunch of wires suspended between two support rods, which are held in place by mica spacers, which connect to the glass bulb;
so when you yell to the glass (or tap it with a screw driver), it will vibrate according to your voice, which will be transferred to the grid via mica and supports;
a vibrating grid will modulate the plate current, and become amplified in following gain stages as if it were a regular signal input and finally become audible in your speaker;
it is not actually necessary that the inards are loose for them to vibrate; a violin string vibrates as well when excited despite it being well fixed on both ends ...
the nasty thing is, if a highly microphonic (1st stage) tube picks up the sound from the speaker and the amp has sufficient gain you could even produce a sustained feedback oscillation - usually a whistle;
if gain is lower than necessary for sustained oscillation the microphony phemomenon may still give rise to frequency dependent distortion because different parts of the tube exhibit different resonant frequencies;
resonances are usually in the kHz range, 100Hz vibration from the transformer is not likely to create problems via microphony;
whether mechanical dampers actually improve anything I have no experience with ...
snakeoil BS.
buy tube types with hardened construction against microphonics...
Tubes have vacuum inside, therefore they are cooled by infrared radiation only. Not by convection. That´s why, the plates are black.
Putting anything on glass will make it worse.
Heat problem is on inside metal elements, NOT the small heat when you touch the glass..
