Hi all, I'm interested in installing a tube buffer between my active pre and one of my amps, a class D. I have a two way horn system with an Azura that currently is driven by tubes from 600 HZ up, but I'm adding another small treble horn/CD and due to space constraints it's easier to add another class D module to an existing chassis rather than another tube amp to drive the small horn. Buuuut, I'd really like to inject some tube goodness here, but it's got to be balanced in and out. Can't find anything manufactured with bal inputs/outputs, so it looks like I'm going to have to build something.
Does anyone know of a kit or a good schematic for this? I could also build a pair of Nelson's H2 generators, I'm pretty sure I read somewhere they can be run with XLRs.
Any ideas or suggestions are very welcome, thank you.
Bryan
Bryan
Not really pure tube buffer but this one might fit your need: https://www.etsy.com/listing/147415...499&click_sum=dfcda2ef&ref=shop_home_active_4
