Tube amplifier mods
Hello! Good! It seems a good amp.
Is it an american amp? That's because of the 6l6 outputs...
How do these sound in hi-fi? I only know them in guitar amps...
And that input pentode stays quiet or it is microphonic like many small pentodes?
You also have some strange capacitors values (235uF? 😕 )...
What resistor have you changed?
6L6GC is a very good tube in HIFI, actually it was designed for PA amps tho. The resistor i removed was between the 120µF and 100µF cap on the schem, why some of the cap values it odd is because its 470µF caps in series. I built this amp from scratch using chassis, OPT and PT from a old organ amplifier, the guys on geek.scorpiorising.ca helped me with the design of the amp. 🙂 The input 6AK5 is microphonic, you hear *dinnnnggg* in the speaker if you tap it, you even hear some faint clicks with a echo effect when you turn B+ on from the cathode and grids when they heat up.
Oh yes, that resistor is just useless (if not bad) when there's already a choke to isolate the driver stage from the outputs. Good design!
I bet that every pentode you tried in the input stage was microphonic... I remember a design somewere that used a power pentode as an input, maybe a 6V6 or similar might work... they are less microphonic (but worse sounding)... just to try...
I didn't know that 6L6 were used in hi-fi (other than in american designs). I supposed that beam power tetrodes just don't cut it in high-fidelty outputs... What are their sonic characteristics against well known outputs (EL34, EL84, KT88, 6550...).
Edit: oh sorry actually some of the tubes I mentioned as regulars hi-fi are in fact beam pentodes...
Hi Giaime,
Many 7581A's over here are labled KT-66 also. On the same bottle. When I looked KT-66 up I see plate diss ratings of 25 and 30W depending on the source. The 6L6GC is indeed 30W as you stated, the 5881A is 25W. THe 6550A and KT-88 I see rated at 42W diss.
So there is some confusion on the KT-66 rating (I've always assumed it was 35W due to the dual branding on the 7581A).
So aside from that, do you see any other errors?
-Chris
