S smgeiger Member Joined 2018 2021-01-21 12:56 am #1 2021-01-21 12:56 am #1 Iʻm installing the electrolytic capacitors. The instructions call for 5 each 4700uF 16V. My kit came with 5 each 8200uF 16V. Is it ok to use these? Thanks! vkung Member Joined 2005 2021-01-21 5:05 am #2 2021-01-21 5:05 am #2 8200uf 16V is the correct capacitors. You must log in or register to reply here.
