TSSA V1.6 Errata
Guys, as I'm prepping a Farnell order to have parts before weekend, I want an advice that might be slightly out of your competence. Still, would like to know what you intuition says.
I'm almost sure that my speakers would benefit from lower impedance of this amp. Although I have never done SMD. Should I risk replacing those resistors without special equipement like smd tweezers? Same question for idle current stability mod.
