• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
TSA8498B(Apt-X): 4 x 100W Class D Bluetooth Audio Amplifier Board
Hi everyone,
I’d like to introduce you to one of our popular products, the TSA8498B (Apt-X): a powerful 4 x 100W Class D Bluetooth Audio Amplifier Board. This is a 4x100W audio amplifier board with a new AudioB plus Bluetooth module that supports Apt-X. It's integrated 2xST high performance TDA7498 which supports dual channel audio amplification. Each channel is capable of outputting nominal power simultaneously and continuously. This board can be powered by any DC14V-39V* power supply. The power input port can be a power jack or screw terminal. The DC input jack is 2.5mm with positive core polarity, And if you use a screw terminal, please pay attention to the polarity!
It has a smart cooling system, and the fan does not work in normal cases to reduce the noise. The fan only starts when the chip temperature is > 65°C. Once the temperature goes down, the fan stops running.
It's perfect for your Hi-Fi application, the audio source can be RCA input or Bluetooth. Compatible with all Bluetooth devices that support media audio, including iPhone, and Android. Let your smartphone paired with this board, play music. So easy!
We tested it. It also works well with 12VDC power. But we suggest using DC14V-39V power if possible.
Features:
  • Size: 15.5cm x 11cm
  • Apt-X supported
  • Smart cooling system
  • Bluetooth 5.0
  • External mute control port
  • External Bluetooth/LINE IN control port
  • Working voltage: DC14V-39V
  • Over/under voltage protection
  • Over current protection
  • Over temperature protection
