Trying KiCAD 2 questions
Me my dumbass,made a schematic in standalone schema KiCAd.
Not using the projekt manager.Now question nr 1:
If I make a project can I import a schema that is done on KiCAD?
Question 2:If I run update the pcb from the schema I get cannot find footprints.. how do I get it to find the foot prints.
Hi Åke,
All KICAD files are plain text. So you can create a new project, open your existing schematic in a text editor, copy the contents, open the schematic in the new project with a text editor, and paste.
Each symbol in your schematic has a "Footprint" field. These tell KICAD what footprint to use when creating (or updating) the PCB.
You can edit the symbol properties and click in the Footprint field. You should get a folder icon to the right. Click that and you can browse the footprints in your libraries to pick one.
Alternatively you can do the whole schematic as a batch by selecting Assign Footprints... from the Tools menu (or clicking the little icon in the toolbar that shows a red opamp over a green 8-pin-dip).
Jeff.
1. I would just copy the file to the dir you make for your (newly empty) project and rename it to the .sch/.kicad_pcb name. Then you can see it in your project.
2. In project manager you can setup up the lib you want to use
I just started using KiCAd and I'm starting to like it. First, start everything as a project. Kicad works better that way. And secondly, there are a ton of YouTube videos teaching how to use KiCAD. My personal favorites are from John's basement.
Regards,
Dan
