TRW Capacitors Question
Bargain.
Hi Nelson, thanks.
Amazing what you can get for $5.00 nowadays.
I bought two large boxes I believe were used for aircraft wiring loom testing - the front panel is covered in very usefull (to me) center off/on/mom toggle switches.
The boards are covered in those caps, green resistors marked RN55D, and old (obsolete) high quality op-amps and buffer IC's.
These machines were made by Texas Instruments, and by the look would have cost a modest house.
Looks to me like a little goldmine of very high quality parts !.
Eric.
More likely mylar, but TRW made good quality components.
If you've got a digital voltmeter and a DC voltage source (a 9V
battery will do), charge up one of the caps and then short
the leads together momentarily. Wait a couple of minutes
and measure the residual voltage; if it's around a tenth of a
volt or so, it's probably the Good Stuff.
