Troulbe with Bias on S150 Series II
I'm refreshing a Threshold S150 Series II amp (a nice sounding little gem). All was going well until I went to set the bias. The one side went without a hitch. However, the other channel is giving me some trouble. The bias level maxes out at 600ma. The bias value climbs up and down, but will not go past 600ma.
What could be the issue? Could one of the two bias transistors have a low hfe? Looking for some feedback. I've done one other S150 Series II without any issues.
Depending on the specific version, there is a resistor in
series with the potentiometer which limits the maximum
bias voltage. You can reduce the value of this resistor and
see if that does it. If it doesn't, you have to check to see
how much current is going through the bias circuit - I would
then look to see if the constant current source for this part
of the circuit is delivering.
You can use the other channel for a reference.
