Tripath TA0104 Eval Board Problem - Help!
I have an original tripath eval board with the TA0104 module on which has been working fine till a few days ago when the on board relay for the outputs stopped clicking in a few seconds after the power is switched on. Checked the relay manually and works fine. 0104 module seems to work fine. Has anyone come across this problem before?
