Is it not a UK model?, we used to be a Kenwood/Trio dealer but I don't have a manual for it, nor do I remember that number?.
It is a uk model !!
I have sold many of them in the late 70s early 80s
As i remember it was completly unexceptional.
Nothing good nothing bad I felt that Trio lost there way at this time
I was just around the time that Trio stopped using BHMorriss and co And imported Direct.
It was a very simple device
Regards Trev
Regards Trev
It might predate us as a Kenwood/Trio dealer than?, personally I've still got a KA660, a great amp!.
Thanks all ive repaired the amplifier the fault was
the out put transistors 2sb595 and 2sd525
i need the circuit so that i can set up the bias ive set it
at 15mv across the 0.47R emitter resistor 30ma
i would just like to sure
thanks big jim
thanks big jim
Thats about right
i assume you have given it time to settle down.
i normally give the amp a bit of driving first so that the sinks are warm to the touch and then adjust the bias
Dont get me wronge re my earlier comments they were a good value for money amp!
Just nothing over special !!!
regards Trev
regards Trev
big jim said:Thanks all ive repaired the amplifier the fault was
thanks big jim
Advantage of a stero amp, you can always check what the other channel is set to - on the assumption that one might still be correct?.
Nigel
Do you have a manual for Trio KA660
I shipped my stuff from England, Trying to Fix my amp.
ps could you tell me more on my amp? ie year.
I got given it by my brother.
Hi guys,
if someone has this service manual (Kenwood KA 660), please be so kind and send it also to me.
thanks in advance!!!
Sorry about not seeing the previous question, I too have a KA660 (which is working perfectly, and I've been very happy with). But because I've got one, I have the manual at home - and my attic workshop is currently in rather a mess as I'm in the process of doing some work there.
If I come across it, I'll grab it - but it could be in any number of places.
What are your specific problems anyway?.
What are your specific problems anyway?. [/B][/QUOTE]
have clean the inside buts seems to have a problem with right channels on both speaker settings and is a little crackley when changing Loadness ect... want to get it looked at and be nice to give them a manual.
Thanks in advance
Thanks in advance
Guys,
sorry can some one provide me the service manual of Amp Kenwood KA-1500 ..
I havo to repair it for my girlfriend..but the amp has been tamperred from a vety bad technical guy..
Please help me..
thanks to everybody, Luciano!
Please help me..
Hi all i have manuals for the KA660D KA3700 KA9100.
If any one wants a copy email me.
all the best jim
all the best jim
Hi Jim,
thanks for your support..
Please, if you can send me a copy of KA 3700
i'm looking for some info on the KA 1500 .. but i hope that have some other info on other KA amplifier can be anyway helpfull..
Thanks in advance!..
i can not email you due to the fact that i'm a new member of this forum..please, check my email add.. on my profile..
Thanks, Luciano
Thanks, Luciano
- Trio Ka1500 Amplifier
