Tried new things on sysasim 5_3 amp
hi, here is the sysasim design and i made change on only power transistor with 2sc2922 and 2sa1216. i dont know is there need to change resistor too. need help. i had power the amp, it works nice but only the power transistor gets too hot. how can i use this transistor on this board?
thank you
very nice sound
yes, now it's works. no more getting too hot. very nice sound with 2sc2922. i loved it.
i didn't change anythings at all. i found c18 was wrong number now i just corrected it, thats all. thanks lots.
i found 2sc2922 sound quality is more btr then 2sc5200.
thank you.
vlu wrong
hi, the vlu was 4.7nf but it should b 47nf
now the question is, power supply should b 36v. my transformer is 56 volt dc. it functioning well..no abnml heat at all. do you think 56v should b ok or should go down to 36v? i am not good in electronics.
thank you.
