Hi all i am trying to fit a trichord clock 4 in my modified marantz cd 6000 ki.
the fitting instructions i have found are as follows.
1 remove clock
2 remove capacitors 2329 & 2330
3 connect 2329 & 2330 together
4 remove smd resistors 3325 & 3326
5 clock ground wire in either of the removed capacitor holes
6 clock output wire where the clock was. solder in top hole of removed clock
then there are other people say
1 remove clock
3 remove smd 3325 only
4 clock ground in either of the removed capacitor holes
I am confused as what to remove as i dont want to damage the player or the clock if i remove or leave something in place
so if anyone can give me a detailed instructions on fitting this would be gratefully appreciated
also i have the schematics for the cd player
and yes i have looked at trichord website for fitting instructions but its not an exact fitting instructions for my player.
1 remove clock
1 remove clock
Hi P.What do Trichord say?
I have always found them to be really helpful.
P.
didnt even think of that so done what you suggested.
absolutely fantastic chap to speak to and very knowledgeable.
was told the exact fitting instructions so the soldering iron is coming out in the next few days.
hopefully all goes well
thanks again for that P.
