Here are the user models I've collected. I only want to add user created models here; this way, the models have been scrutinized and are more likely to be close in performance to the actual devices.
*Models from Andy_C, probably very accurate:
.MODEL mjl3281a_x npn IS=9.8145e-12 BF=438.0 NF=1.00 VAF=38 IKF=19.0 ISE=1.0e-12 NE=1.1237388682 BR=4.98985 NR=1.09511 VAR=4.32026 IKR=4.37516 ISC=3.25e-13 NC=3.96875 RB=3.997 RE=0.00 RC=0.06 XTB=0.115253 XTI=1.03146 EG=1.11986 CJE=1.144e-08 VJE=0.468574 MJE=0.34957 TF=2.6769e-9 XTF=7500 VTF=3.0 ITF=1000 CJC=1.093685e-9 VJC=0.623643 MJC=0.482111 XCJC=0.959922 FC=0.1 CJS=0 VJS=0.75 MJS=0.5 TR=1e-07 PTF=0 KF=0 AF=1 Vceo=200 Icrating=15 mfg=OnSemiconductor
.MODEL mjl1302a_x pnp IS=9.8145e-12 BF=122.925 NF=1.00 VAF=40 IKF=19 ISE=9.18577762370362E-07 NE=5.0 BR=4.98985 NR=1.09511 VAR=4.32026 IKR=4.37516 ISC=3.25e-13 NC=3.96875 RB=3.30 RE=0.00 RC=0.06 XTB=0.115253 XTI=1.03146 EG=1.11986 CJE=1.561e-08 VJE=0.781803 MJE=0.433868 TF=3.257e-9 XTF=1000 VTF=2.0 ITF=260 CJC=2.346838e-9 VJC=0.27876 MJC=0.411324 XCJC=0.959922 FC=0.1 CJS=0 VJS=0.75 MJS=0.5 TR=1e-07 PTF=0 KF=0 AF=1 Vceo=200 Icrating=15 mfg=OnSemiconductor
.MODEL Q2SA1837_x PNP ( IS=2.39372559E-10 NF=1.304015937 BF=300 VAF=273 IKF=2.087725944 NK=0.94719458 ISE=1.46829699E-11 NE=1.526663542 BR=4 NR=1 VAR=20 IKR=1.05 RE=0 RB=1.8 RC=1.65 CJE=4.7407E-10 VJE=1.1 MJE=0.5 CJC=8.6700E-11 VJC=0.3 MJC=0.3 TF=1.642191E-09 FC=0.5 ITF=1.076260106 XTF=5.868994022 TR=1.38U)
.MODEL Q2SC4793_x NPN ( IS=1.8E-09 NF=1.43 BF=146.38 VAF=273 IKF=2.6 NK=0.95 ISE=6.286997E-10 NE=2.223629 BR=4 NR=1 VAR=20 IKR=1.05 RE=0 RB=1.7 RC=1.25 CJE=5.96964E-10 VJE=1.1 MJE=0.5 CJC=5.78E-11 VJC=0.3 MJC=0.3 TF=1.22678E-09 FC=0.5 ITF=10 XTF=99.52253015 TR=983N)
.MODEL BAV21_x d
+IS=7.294112E-09 RS=0.706 N=1.904350
+BV=250 IBV=100e-6 NBV=145.396351
+VJ=0.666016 M=0.084417
* Typical capacitance and reverse recovery time
* Trr = 26ns
+CJO=1.172445e-12 TT=36.5e-9
* Worst case capacitance and reverse recovery time
* Trr = 50 ns
*+CJO=5.0e-12 TT=68.1e-9
*Models from Syn08:
.MODEL Q2SA1407_syn08 PNP ( IS=15.2F NF=1 BF=416 VAF=254 IKF=90M ISE=3.66P NE=2 BR=4 NR=1 VAR=20 IKR=.135 RE=7.63 RB=30.5 RC=3.05 XTB=1.5 CJE=22P VJE=1.1 MJE=.5 CJC=7.1P VJC=.3 MJC=.3 TF=397P TR=276N)
.MODEL Q2SC3601_syn08 NPN ( IS=15.2F NF=1 BF=416 VAF=254 IKF=90M ISE=3.66P NE=2 BR=4 NR=1 VAR=20 IKR=.135 RE=5.63 RB=22.5 RC=2.25 XTB=1.5 CJE=18.3P VJE=1.1 MJE=.5 CJC=5.91P VJC=.3 MJC=.3 TF=397P TR=276N)
.MODEL Q2SA1930_syn08 PNP( IS=10.000E-15 BF=210 VAF=78 IKF=10.000E-3 XTB=1.5 BR=.1001 VAR=100 IKR=10.000E-3 ISC=10.000E-15 CJE=3.252E-12 CJC=63.196E-12 MJC=.33333 TF=83.239E-12 XTF=10 VTF=10 ITF=1)
.MODEL Q2SC5171_syn08 NPN( IS=10.000E-15 BF=210 VAF=100 IKF=10.000E-3 XTB=1.5 BR=.1001 VAR=100 IKR=10.000E-3 ISC=10.000E-15 CJE=2.0000E-12 CJC=38.866E-12 MJC=.33333 TF=83.239E-12 XTF=10 VTF=10 ITF=1)
*Models from Christer, very simplistic, give very good performance in simulator (perhaps better than the actual devices?). Christer himself did not guarantee the accuracy of these.
.model 2SD669_Christer NPN (IS=5p NF=1 BF=250 ISE=5p NE=1.5 IKF=3 VAF=150 RB=1 RC=0.25 RE=0.25 TF=1.14ns CJC=50p )
.model 2SB649_Christer PNP (IS=5p NF=1 BF=250 ISE=10p NE=1.5 IKF=3 VAF=75 RB=1 RC=0.25 RE=0.25 TF=1.14ns CJC=50p )
* Keantoken modified these models of the 2N5769/5771 complementary HF switching transistors. The models are very accurate regarding DC characteristics but the AC modeling wasn't modified from the original model. Here is the thread: http://www.diyaudio.com/forums/software-tools/151168-bjt-spice-models-reality-check.html
.model 2N5769_k NPN(Is=1.2f Xti=3 Eg=1.16 Vaf=100 Bf=88 Rb=45 Ikf=200m Ise=33f Ne=1.7 Xtb=1.7 Br=1.365 Nc=2 Isc=0 Ikr=0 Rc=.6 Cjc=2.83p Mjc=86.19m Vjc=.75 Fc=.5 Cje=4.5p Mje=.2418 Vje=.75 Tr=1.073u Tf=227.6p Itf=.3 Vtf=4 Xtf=4 Vceo=15 Icrating=200m mfg=Fairchild)
.model 2N5771_k PNP(Is=1.2f Xti=3 Eg=1.16 Vaf=100 Bf=125 Rb=45 Ikf=100m Ise=62f Ne=1.7 Xtb=1.7 Br=1.365 Nc=2 Isc=0 Ikr=0 Rc=3.75 Cjc=2.77p Mjc=.1416 Vjc=.75 Fc=.5 Cje=2.65p Mje=.3083 Vje=.75 Tr=4.033n Tf=118.5p Itf=.5 Vtf=3 Xtf=6 Rb=10 Vceo=15 Icrating=200m mfg=Fairchild)
* Also by Keantoken, but not as accurate as the 5769/5771 models. Hfe is optimistic.
.model BC547C_k NPN(Is=32.53f Xti=3 Eg=1.11 Vaf=100 Bf=620 Ise=299f
+ Ne=1.583 Ikf=.7695 Nk=.5467 Xtb=1.5 Br=6.313 Isc=138f Nc=2.053
+ Ikr=.187 Rc=.4216 Cjc=5.25p Mjc=.3147 Vjc=.5697 Fc=.5 Cje=11.5p
+ Mje=.3333 Vje=.5 Tr=10n Tf=410.7p Itf=2.204 Xtf=66.65 Vtf=10)
.model BC557C_k PNP(Is=32.53f Xti=3 Eg=1.11 Vaf=100 Bf=580 Ise=318.3f
+ Ne=1.542 Ikf=.6049 Nk=.6086 Xtb=1.5 Br=6.501 Isc=179.5f Nc=1.832
+ Ikr=.1402 Rc=.4026 Cjc=9.81p Fc=.5 Cje=30p Mjc=.3333 Vjc=.5
+ Mje=.3333 Vje=.5 Tr=10n Tf=516.2p Itf=13.36 Xtf=1.289K Vtf=10)
.MODEL BAV21_x d
* Trr = 26ns
* Trr = 50 ns
*Models from Syn08:
