Got 2 transistors marked BR and FR
Anyone know what the part numbers are ?
Also transistor marked BE and 8C or HK
Looks like an orion drive board.
Just out of interest. What happend and why do u need to replace these parts?
Same here, hope you are not just shotgunning, replacing them without troubleshooting, praying that is the problem.
What are symptoms/measurements/complaint?
I’m not replacing them for no reason .
I wanted to know the parts numbers Incase I found 1 to be defective so I have a reference if needed
Ok.
Perry Babing linked to an incredibly useful reference table.
That said, and just 2 letters being incomplete information, that is just a starting point, at least youb reduce infinite possibilities to, what? ... 6 - 8?
Then you refine search by taking note of package (SOT23, etc.), voltages present, etc.
Already knowing it is, say, "NPN transistor" helps.
Most small signal transistors are roughly interchangeable, so must so that Elktor Magazine published their famous TUP TUN DUS DUG replacement tables.
All transistors and diodes in each section are mutually compatible.
This is just one of those tables .... from 1977!!!!!
BR= 2SC2412K
FR= 2SA1037AK
Referencing the datasheet from rohm semiconductor for 2sc2412k B is the part. R is the HFE ranking.
You can see in the datasheet that it is complementary to 2SA1037AK. Then searching that transistor you see it has a part marking of F with HFE value of R.
Ive confirmed these are the parts on that board from partially rebuilding one due to water damage.
FR= 2SA1037AK
- General Interest
- Car Audio
- Transistor Question
