recently bought via ebay a small tube amp that looks very close to a heathkit UA-1 schematic wise that is.
TUBES ARE
6BQ5 x 2
12AX7 x 1
6an8 x 1
However, there is absolutely no label as to who made this or a manufacturer
It is obviously a kit of some type
The only markings are on a piece of the assembled unit
PA92-9 also a number 283 seperated by the power cord
Power transformer has PA-227 and 798852 stamped on it
measured output was green pair: 162.7 volts
7.6 volts
Audio transformer has pa-228b, 138913, and 28536 stamped on it
I have looked thru every old transformer catalouge i can find and cant see either of them listed anywhere
If anyone can find out some info on the transformers like who made these things, i would appreciate it very much
Thank You
Mike
TUBES ARE
6BQ5 x 2
12AX7 x 1
6an8 x 1
7.6 volts
Thank You
Mike
transformers....
Mario, these are beautiful transformers, but way over my head and totally outclasses anything i have or work on, the info is very much appreciated.
However, im just trying to find the specs for what i do have atm,which i fear will be impossible since all the info i have is allready posted here. i will TRY o post some pictures asap.
Thanks again, but im way out classed on this one.
