Transformer with 24v-CT & 6v secondaries - looking for sources.
I'm trying to replace a PT in a Proton 1100 preamp (aka NAD 1150). This unit was left on all summer, in a hot garage, in Atlanta, and the design supposedly pushed the PT pretty hot to begin with, so I'm not surprised it went bad. It blows fuses instantly with mains power applied and all secondaries disconnected. It's not $$ but I like it and have had for quite a while.
It has dual secondaries - one set is center tapped (I believe) and supplies ~24v (? -for a ~30v rail), the other set supplies 6v for the power LED. I can't really tell much about it, there's no labels on it other than a part number, and since it's bad, I can't measure what it's actually producing, but those are what the schematic calls for. Does anyone know of a drop-in or close equivalent? - I realize that there are other ways to get that supply, but I'd like to stick to the original preamp design and not have dual PTs, cut sheet metal, etc.
Pic of xrmr in situ, attached, schematic at link HERE.
Get it rewound?
Find the service manual, will tell you about the transformer.
I have considered that. I've used a Guy up in Maine for several projects before and he's first-rate. Service manual (in the link above) has almost zero info about the transformer, just a part number and a description of the operating voltages afterthe regulation block.
Everybody is converting incandescents to LEDs these days. Unless you like changing light bulbs. If the 6V winding were also feeding something else critical, you could use a toroid type trafo and put a 6 volt winding on with bell wire.
