Transformer Wiring
Hi!
I want som advice concerning how to best wire the mains transformer in my coming tubeamp. I need about 260 V@250 mA to the outbut tube and same voltage or maybe a little higer (se D) to the drivestage @20 mA.
In whitch case do I put the less stress to the transformer.
Regards Anders Brandt
A will give you 0.707 X voltage with 1.414 X current.
B will give you 0.707 X current but 1.414 X voltage on each winding.
C will give you similar results to B per winding.
D must be a different transformer and a multiple of already described.
Don't forget, if the transformer is rated at 100V/A then that is all you can get, in any configuration.
None give either more or less stress on the transformer, the stress is down to smoothing capacitors and output drawn.
Yes, 'D' will give independent supplies, with one being a bit higher voltage than the other.
However, my preference is 'C'. The reason is that the total load (current) is placed fairly across the two similar 195 VAC windings. Since P = I²R, looking at just one winding (for analysis purposes), the I is halved. Its 'R' doesn't change. Therefore the P/P = (½)² or ¼. But of course, there are 2 windings involved, so ¼ ⊕ ¼ = ½.
Still, half the power dissipation during capacitor charge cycles … is a worthy outcome.
Moreover, the 'total power' available is at the limit of the transformer without balance issues to speak of. Supposing that the pair of 195 V windings are indeed well matched to each other. co-wound equal-turn windings are the best.
Down-wind of the full-wave bridge, is filtering … and tho' it wasn't part of the discussion, 'regulation'. I highly recommend active regulation (either absolute value, or fraction-of-quiescent) via MOSFET series regulators (plural) to obtain the output, and driver voltages you desire. The technique is simple, the results better than expensive high-current chokes or large-can capacitors. It is 2020, after all!
Anyway, I apologize for the unsolicited off-topic opinion. It seemed related.
⋅-=≡ GoatGuy ✓ ≡=-⋅
The transformer have besides those three windings I have mentioned two 3,15V@7,5A for the filaments. The total power is 200W.
P=U*I= 195*0,39=76VA
-"- 195*1,42*0,25=69W
I wish I had a little bigger differense. I may try C like you say GoatGuy.
