Hello,
I have decided to have a ago at building a tube amp and have chosen a push-pull using the KT88 shown here. But before I get started I would like to get an idea on how much this thing is going to set me back. From looking at the WES Components catalogue I have an idea on prices for tubes, but I haven't been able to find any suppliers in Aus of transformers. Since this is my first amp I am not looking for anything to flash.
Any help by aussie diyers on suppliers of transformers, valves or any other components would be greatly appreciated.
Cheers
Jye
Cheers
Jye
Surely there must be plenty more around but i always hear good things about these xformers:
TURNER AUDIO
Cheers,😉
TURNER AUDIO
Cheers,😉
hi there,
try
www.evatco.com.au
this is where i get all my suplies from. they have huge range of tubes as well as the trannys you're looking for. The guy who owns it is also super nice, and is always happy to help you out.
you can also try contacting the aussie hammond office,
ccookson@hammfg.com
if you want something other than hammond trannys, then i can't help. these are all i've used... not necesarily because they're the best, but just because they're the easiest for me to get.
anyway, hope this helps.
try
www.evatco.com.au
ccookson@hammfg.com
actually, i found this in my favourites... it is a directory of a whole lot of aussie valve amp suppliers. don't think all of them sell tranny's, but there should be some who can help you out.
http://home.mira.net/~gnb/elec/valveaus.html
Cheers guys,
I think I will have to do a bit more saving before taking the leap since it looks like I will be getting hammond trannys.
thankyou once again
Jye
thankyou once again
Jye
Hi Jye,
Try Voller Transformers, 39 Advantage Rd, Highett, Victoria, Phone (03) 9553 3025. Paul will make the transformer to order and probably charge you less than importing, which is just not necessary.
Hugh
Hugh
