I've got 2 toroid transformers (Noratel model TA160/30) that humm significantly when I use a 40ah SSR to switch the 230v on.
Anyone know why this happens and if there is anything can do to fix it?
The SSR probably uses a triac as switching element that will switch on once the voltage across the terminals has reached a certain voltage (I'd guess around 10-30V). This provides the voltage needed to operate the SSR circuitry on the switching side. And it also cuts off the first few percent of every sine (half)wave which leads to a current spike through the trafo at triac turn on time. From my POV there's little to nothing you can do about that except use a mechanical relay.
Yes, the ones I have use traics and I started looking for mosfet SSR's but they seemed harder to find and more expensive.
I am building a soft start as well and consider using the triac ssr for the NTC soft start and then shorting the SSR/mains feed with a mechanical relay.
This should bypass the triac issue (even though there may be a bit of humming at the start). Not sure though if the SSR will be "unhappy" being shorted?
Mark Johnson made a soft start board for people: PCB: low voltage On-Off switch drives AC mains relay \ includes soft start .. H9KPXG
