I found a transformer rated 24v-0-24v 600w max for a good price
Can this be used with IRS2092 board like this?
350W IRS2092 + IRFB23N20D Class D Power Amplifier Board (Dual Rectifier)
Or something from the LD15 or similar?
What power output could I expect into 4R? 1 board vs 2 boards?
Capacitors for this transformer?
Thanks and regards
Randy
Thanks and regards
Randy
Many of the irs2092 amp boards are based on the Infineon reference design IRAUDAMP7. There is a chart that shows the approx power output with different rail voltages here https://www.infineon.com/dgdl/iraudamp7d.pdf?fileId=5546d462533600a40153569ad5ba2bf9
Your transformer would give you about -/+34vdc so I’d expect somewhere around 125W/4ohms
