transformer for aleph2
hey all!
im currently trying to source a transformer for my aleph2 monoblocks. as some of you know, i want to overkill the whole thing, but im having a problem finding the transformer i want. i want a 1.5kva, with 33v secondaries (right?).
well, plitron only has a 1.5kva with 38v secondaries an up. would this work?
i got a quote from victoria magnetics, but they are $168 each. thats a LOT! plitron is only $113.
any ideas?
From my experience purchasing from Plitron, they will make the transformer with whatever voltage you specify for the secondaries. I have ordered non-standard voltages and there was never an objection or additional cost.
The supply voltage limits specified in the LM3875 datasheet take into consideration an 8 ohm load. If you are planning on driving 4 ohm speakers it makes sense to use secondaries with voltages below the maximum allowed and avoid the current limiting circuit to kick in. However, I haven't tried it. Considering that you already have it assembled and working, try better heat sinking first and check how it behaves and sounds.
Happy experimenting!
yeah, i will...
i had the IC's clamped to my heatsink, and it melted the clamps 🙂 it got HOT. but i also had it driving some kappas and boston acoustics VRM90's in a LARGE sound-dampened listening room at HIGH volumes, in the cardboard box of course 🙂
ill try much better heatsinking, and see. i did like the sound. but maybe 20v or 22v could be a good compromise, it was a little lacking in bass.
