I have what may seem quite a simple question. I have purchased a Chinese pre amp module from ebay. It uses 2 x 6N11 tubes and the ad said to use 110VAC supply (HT supply?), no current specification, so I assume mains voltage, as I have 240VAC in the UK, this is out of the question, which brings me around to asking what rating transformer should be used?
I have ordered a 60VA/110VAC toroidal transformer for the purpose, but it appears to have 130VAC unloaded, is this a major issue and what current draw is likely for these tubes? Info is sparse for this module, so I thought I'd ask some experienced valve users. 🙂
A 6VAC 30VA heater supply is recommended BTW, so a 2 x 6V 60VA traffo could be used to implement a small diy DAC as well.
I would not considerit a major issue since my line voltage typically runs 125-128V. 130VAC is not unusual in the USA any more.
I presume you have ordered a 240VAC to 110VAC(130VAC) and plan on running it to step the voltage down.
There are two ways you can run it, (1) in line as a step down to power the unit, (2) as a line bucking transformer.
Either way should be fine. Just be sure to connect your earth to the chassis as well.
It sounds like you are ordering a seperate filament transformer. Is this correct?
Please post a link to the module on ebay so I'm sure I understand.
The ebay link is here....
Pre-amp Tube Amplifier 6N11 SRPP Kit for DIY New on eBay (end time 06-Feb-10 03:17:24 GMT)
The board looks like this, although mine was sold as being 110VAC supply.
To be honest, with the good weather, the project has taken a back seat to a whole bucket load of house diy jobs.
One day I'll finish a project. 🙂
